What exactly does this table do? I see maximums and my VE is dialed in however it exceeds MAXIMUM VE in every RPM range. Should I raise the limits of this table to meet/exceed my current highest VE # for each given RPM range?
No one?
I asked this same question and never got an answer either, must be something that isn't that important, but it would be nice to know what it did.
Well I set mine 100pts higher than the highest # in each rpm range.
I'll try that too, thanks.
Anyone?
i've noted the max value for each row of the stock VE table were listed in the max ve table so on my tune i did the same. When i tuned the VE and the max values were changed, the same new max values has now been placed in the max VE table.
Don't know what is the meaning, maybe a double check table when the PCM skip from the VE to MAF...
