1 Attachment(s)
Hummer H3 Turbo Stabily
Hi... my firts time tunning a 2006 Hummer H3 3.5.
a few day ago i finish the turbocharger costruccion in a 2006 H3 3.5L and the naext step was a reprogram the ECU i star in 6 PSI with a 9.5 AFR but i have a big problem when i run the H3 and change to second gear the stability system fail :banghead: and the AFR come to lean. I try to disable the stability system but i dont find how to do it. Please somebary to help me :pray:
Attachment 53818
thats an ecu access failure...you should be talking to hpt technical division. you can send them a message from the main page or through your customer center.
