I need an Express van file to do a DBW to DBC swap.
2003 would be best. IF you have a 2003-05 post what you have. I might be able to use it too.
Thanks!!!
Thanks!!!
this is from a '03 6.0
awesome....thanks for that.
I am going to submit this to the repository if you don't mind. I'm sure someone else will need it later.
no problem... btw that file is a one ton van with 4l80e if it matters for you
4L80e is fine. They are going to be running a TH350, so the trans will be a non-factor.
I tried to open this tune from the repository and had no luck opening it says its out of array. you guys wouldn't happen to have a version of this tune saved in a different hp tuners version would you???
