4.2 electric fan help
I have a 05 trailblazer with the 4.2 and would like to switch to electric fan. I would like to beable to use my hp tuners to control the elctric fan like I did on my 05 silverado. The fan is done with pulse withs or something like that. I am not sure if I can hook into the harness at the core support were the elctric clutch hooked into.
Please scroll down to post 7
Never done this, but,
You could you not goto fan table, select the temp you want to fan to turn on and put 100% there and up,
Then where the wire goes to fan, put that to power a fan relay.
Do the same with AC pressure table?
Just a thought
Unless I am completely missing something I don't see that a option like my 05 ls1 has. Here is a tune you can see what I am talking about.
System > Fans
fan desired% vs Coolant temp
Lets say you want fans to turn on at 199*
from 199* and up put 100%
Then you would use the Fan PWM wire, hook into a relay, to turn relay on.
Then wire relay to the fan motor.
I cant see why this wouldnt work but I have never done it.
But I am just not sure this will work like that since I think it is a pulse with thing the fan tab looks nothing like my 05 ls1 like the trailblazer does. I would like to conform that would work before I start I have to finish in a evening so my wife can drive to work next day.
PWM Pulse Width Modified
So for example if it was set a 50%, then it would be on 50% of the Time and Off 50% of the time.
But if you set at 100%, it would be ON 100% of the time, so it would be a constant current and not a signal.
I still have never fixed the clutch fan on my wifes trailblazer just turned the ses light off. But it is starting to affect mileage so I need to get this figured out I finally did find a wiring diagram for the plug that the clutch plugs into. I also would like to here if this will work from someone that has done it since this is her everyday vehicle I can't have down time. Since it is PWM like planethax said can I just set it too 100% were I want it to turn relay on.
