2 Attachment(s)
User defined EIO inputs can not be safed
Hello everybody!
I'm from Germany, so please excuse if my vocabulary is not 100%... I'm currently working on the tuning of my Corvette C7. It's supercharged and I have the following problem with the VCM Scanner:
I did connect a EGT sensor with a little box that transforms the signal of the K-type sensor into a 0-5V signal. This signal I did connect with the analog input #2 of the HP Tuners box. I did set up the values for this input and safe the settings. Here is s screenshot:
Attachment 49417
As soon as I do this during the Scanner is already connected to the car, the analog input works. It shows the exhaust gas temperature and I can log it without problems. But when I close the VCM Scanner or even just disconnect from the car, all settings are gone and it just says "unsupported parameter" for the EIO input #2:
Attachment 49418
I can do what I want, safe the config under a new name or try it under different conditions (connected, disconnected,...). It does not help, it's impossible to safe the setting so I can work with them for the next time without having to set up the user defined input new every time...
Thanks for your help! René.
