I don't understand what you are referring to
I was referring to this
"so what tune adjustment are made to the drive by wire or throttle to get that 1:1 gas pedal to throttle body ratio that's another complaint. "
Electronic throttle, there you will find it.
Ok. thanks I am new to tuning other then buying email tunes any help will be appreciated
canniga has you on the right track. Just be careful if you are unfamiliar with what you are changing. Make small changes, and try to understand what those changes will do under the hood before implementing them. There are MANY guides out there you can purchase to help with using HP Tuners, I suggest you buy and have one handy. The one LaSota racing sells called the Coyote Cookbook helps a lot, at least for me. It won't turn you into a pro, but it will help you understand the why/how and basics of the system.
Yes the coyote cook book will be ordered also. thanks again for the help
