1 Attachment(s)
rich start up problem with 3bar OS
I have been running my car on 2bar speed density for a long time now without any real problems at all. Decided its time to run more then 15psi of boost so I went and upgraded the OS to the 3bar OS. (I converted back to the original tune file first, then converted over to the 3 bar OS.) And yes I did a write entire when switching things over. The problem is, when I go to crank it over for the first time, it goes pig rich. So rich in fact that black smoke puffs out of the exhaust. I've tried re-converting it to 3 bar with the same results. When using the scanner, I notice that the PCM is commanding a huge amount of fuel, (as seen in the pic.) I converted the car back to a 2 bar and everything works fine with that. (yes I switched the map sensor over from a 2 bar to a 3 bar.) Any idea's? suggestions? Thanks
Attachment 41029
