Anyone tuning 2010 camaros 3.6 v6 I'm getting a few codes any help it has twin turbo boosting 5-6 psi intercooled and I'm getting codes p0101,p700 & p069e any help would be appreciated.
P0101 is a maf code
p069e I believe is a fuel pump control module code(I don't believe this is controlled by the pcm)
Do we have a config.for that 2010 computer to data log MAF?
And no I have not corrected MAF airload tables it is being used as blow thru style and I dont see a data logger for that PCM.
This is a project inprgress does my file look some what okay or am I lacking on some areas of the tune? The P0700 & E069 when I disabled catylist heating car is cat less and has turbos mounted under car and we have a front mount intercooler intake temp stays efficient.
You have to create your own config. For logging, in many cases. Or, at least modify an existing one.
Okay thanks
