Need clarification of something for VVT tuning of the LE5
VVT tuning is something that has boggled my mind for quite some time with hptuners and this cobalt ss, but after examining the way the camshaft actuators work I think I finally understand it and I just need some clarification if this is indeed how it actually works. HPtuners gives two 0-25 degree tables in what is presumably crank degrees for low medium and high baro settings for the LE5, but what puzzled me was the direction the cams were going, was the VVT retarding or advancing the cam, this I could not figure out. But to my current understanding with the way the actuators work on the gear, each cam, intake or exhaust, can only move one particular direction on the gear. So for instance with the way it seems to be setup, the exhaust cam gear only retards the exhaust cam 0-25 degrees, and the intake cam gear only advances the intake cam 0-25 degrees. Would this be a correct assessment of how the VVT works? I am basing this off of the design of the gear itself of course and given the fact that there are no negative numbers in the HPtuners adjustment tables indicating that it only moves one direction.
http://www.hostthenpost.org/uploads/...1d158edae0.jpg
