5 Attachment(s)
2007 SKY RL weird problem help, PLEASE
The car is a 2007 Saturn SKY RedLine with the LNF motor, 20224 miles always babied!
Car is equipped with a PCM For Less ECU, but is otherwise stock, and never had any problems prior. I started driving it a few weeks ago and the CEL goes on for a P0101 MAF out of range and it goes into limp mode. I install a new MAF, it drives fine for s short while, but when on the throttle it will rev and boost correctly once, but on the second time it throttles back into what feels like limp mode (4psi) but doesn't throw a code. Oddly some times it resets from limp mode after a few miles and other times it does not.
I've overwritten the PCM For Less tune with 4 customized data tunes and it still does the same thing.
I've checked for boost leaks, system checks OK to 30PSI, no leaks.
I've I've installed a 3rd MAF same behavior.
I installed the GMPP TMAP sensors and adjusted the tune for them, same behavior.
I have installed 3 different tunes from my 2008 Saturn SKY RedLine that I know for sure are correct and still the same behavior.
I have checked all harnesses and fluid levels the car is basically showroom stock perfect.
Any ideas of where to look would be great I have attached a log file or two
--Christian
Attachment 44378
Attachment 44379
Attachment 44380
Attachment 44381
Attachment 44382
