6L90 Shift Time vs Shift Pressure
How agressive are you guys getting on the shift time, and shift pressure tables for the 6L90?
I have a 2010 CTSV that is touching the rev limiter on the 1-2 and sometimes 2-3 shift so im trying to speed up, and firm up the shifts to get it over with before it hits the rev limiter.
I tried taking 20% out of the shift time table in higher rpm and higher torque values, and i tried increasing the shift pressure table by 20% and it doesnt seem to have made a big difference.
The numbers in my shift time table look to be around .300 sec and the pressure numbers seem to be in the low 200s psi.
How aggressive do you guys get here? how big of jumps can i make? can i just put it at .100 sec and 240psi and see if that helps? or is this the kinda table that if you take too big of a step it will just break the transmission?
