Issue with lean condition (AFR 16) meason wide band when forcing open loop operation
Problem Description:
I am suddenly having this weird problem when forcing the ECU (E38) to open loop mode for tuning.
In this mode, my Wide Band O2 (NGK) reads AFR 16. (15.79 in the scanner Table Display) The commanded AF ratio in the table display is 14.68 and the commanded Lambda is 1.0 (I also recalibrated my wide band as a test to make sure it wasn't reading incorrectly)
Details:
I have forced open loop in the calibration config via setting the temperatures in ECT vs. Startup ECT and O2 Readiness ECT (152 Deg C and 256 Deg C) Also set open loop IVT gains to 1
When the config is loaded and the engine started, the wide band reads 16. When I use VCM contols function to manually force the ECU to closed loop = on the AFR on the wideband matches the commanded AFR. When I turn closed loop off again the wide band reads AFR 16.
When I loaded my standard config into the ECU the wide band reads as expected. When I use the Scanner to manually force closed loop off the wideband AFR reads 16 again and returns to normal operation when I turn Closed loop on again. At cold start up on the standard config when the engine is in open loop without intervention the wideband AFR reads normally.
I did disconnect the battery for about an hour as well with no change. I also tried writing entire with no differences. I even loaded an old calibration config file that I used last year successfully via a write entire with no change to the issue so I don’t think it’s a weird setting that I accidently set. (I also used the compare function to look at every settings to determine any differences.) I also installed the wideband on the other bank in case of a weird exhaust leak.
The issue seemed to start after I was stuck in a bad traffic jam yesterday where the engine got pretty hot. (the ECU is located under the dashboard area not in the engine compartment) The intake temp went as high as 53 Deg C. and the coolant temp went to 110 deg C.
Application:
The ECU is an E38 from a 2006 zo6 corvette.
Engine is an LS7 crate motor from new in 2009. The engine has since been modified over the years to FAST 102, NW 102, Ported heads, Cam - Katech K501 (recently changed from Torquer 110), Headers etc… The engine is installed in a mid engine Kit car.
Has anyone seen this sort of issue before?
I will post both tunes and a log in a bit.
Thanks for any help or ideas,
Regards, Peter
