Gen 3 Silverado with gen 4 motor Throttle Body question
Hi,have a 05 truck, redid a gen 4 6.0 for it.I have a X-link adapter. Thanks to some great help on here,I have it running great,with good mpg.The problem has been a REP light and codes P0120, P2135, P1516. This was intermittent and I have replaced the TPS,TB pigtail,added grounds,ohmed the harness, checked for poor gnds,etc.Earlier this week it set the rep light and codes P1516,P2135 3 times in a mile.I have followed the failure records and GM diagnostics with out resolving it.I also followed the T/S document from X-link. I finally changed it back to the original T/b with a 4-3 bolt adapter plate.Instantly no codes or rep.I drove it 35 miles yesterday with no issues.
Here is the T/B I was using:
https://www.summitracing.com/parts/ado-217-2422
My question is will this T/B work with the Gen 3 PCM?
https://www.summitracing.com/parts/ado-217-3153
Also what needs changed in the tune to use this T/B?
Thanks for the help.
