2 Attachment(s)
Symptons of incorrect cam timing? Tuning issues with a car way down on power inside
If you have tuned a car that was later confirmed to have an incorrect camshaft, sprockets, or was simply installed 'a tooth off' what were the symptoms during tuning?
I've got a car here that we tuned about a year ago that had our stage 2 torque max camshaft in an LS1 with a set of PRC 5.3 heads. It made 424 rwhp and 403 rwtq which was respectable for the combo.
Now the same car is back, but with an LQ4 bottom end and our torque max stage 3 camshaft. Same heads, intake, exhaust, etc. Nothing changed but the bottom end and the camshaft to a slightly larger one.
Now the car is dyno'ing between 395-400 rwhp and around 370 tq. When tuned via the maf or in SD there is a huge lean spike initially then it goes super rich. If tuned to correct this, the maf curve and ve tables look all out of wack.... Even though I try to correct it, it really never irons out. Fuel pressure doesn't drop excessively or anything like that during the hit; it is pretty stable throughout the entire run.
I checked the cranking compression and 7 out of 8 cylinders had between 180 and 190. One odd ball cylinder checked 220! 180 would probably be on the high side of what I would expect for a relatively low compression engine and a camshaft that has around 20 degrees of overlap.
Any thoughts on this being a cam timing issue or possibly anything else?
