Originally Posted by
mowton
As far as I can see, your "pig fat than it goes lean" scenario's are a result of DECEL and very minimal delay (like .1 to .2 secs) when PE cuts in, both which are expected. Should be filtered out from your histogram and you should only be using steady state data to be adjusting the tune. You can set TPS, MAP and cell count to filter out these transients and low cell counts (non-steady state data).
Realize you are tuning in SD Open Loop, but MAF curve looks a bit uneven as well. Also as you are FI'd I would have changed the MAP Bondary zone 4-5 from the 90 to like 125 kPa or so.
Ed M
