having some knock with low timing need help
Car is a 2011 auto with One 3 twin turbo kit
80lb ford racing injectors
running around 6.5psi
I have a couple issues but the main one is knock.
I actually didn't know it was knock until I found out negative values are in fact knock....on the overview graph in the scanner they don't show up that way so I didn't think much of it.
Now I'm getting around 2-6 counts and its pulling timing all the way down to 8-10 and a new log it goes all the way to 5.5. Not sure if its real knock or not.
its also very rich...around .72-.76.
Also during WOT shifting between shifts it seems the tps is closing quite a bit...trying to figure out how to fix that. seems to go as low as 30% while 100% is commanded
I have attached a 1/8 mile pass as well as one after I made changes to the trans
Thanks,
