Wow. I was hoping I didn't overshoot but those changes I did from the 7 minute log didn't help with the trims much at all. Try this one and see how it does.
EDIT*****
Use this one; it has new PE settings
Attachment 145619
EDIT*****
Attachment 145619
it wont let me upload the log but that seemed alot better , im still trying to upload the log right now , only a couple of "KR'S" but i think its alot better than it was before
More MAF & VVE changes. That was a good log, this one "should" feel a little better driveability wise. We may want to check with some of the more experienced guys to see if it would be wise to turn off COT since you no longer have Cats.
Attachment 145646
ok awesome ! thanks man , ill try it first thing in the morning !
No cats; right? Are the Downstream o2 sensors removed from the vehicle?
This one has COT disabled along with all DTC's related to 02; sensor 2 set to NER. Attachment 145661
no cats correct , and the back o2's are still there , that completely slipped my mind , could that be causing the kr ?
That won't cause random KR
Sorry, meant to quote the OP's question in post 26.
I saw the changes. Would be nice to see another log though
I appreciate you guys chiming in. I'm using Version 5 of Editor, so if you're using an earlier version, then possible I cant see. Other than putting COT settings back, i cant see anything changed when comparing files; unless I'm overlooking it. Hoping a new log will show improvement for OP.
ill have a log posted here in about an hour , anything specific ? regular driving or should i be rough on her lol ?
Just go for a normal drive for 10 mins and throw one WOT run in there.
Attachment 145665
that seemed way better , i didnt see any kr and i had a little baby WOT , let me know if you want another log
Attachment 145666
another small run around town just in case
thank you guys ! i really appreciated the help . and @ls rob i tried your tune first and that was the one that did the trick so i never got a chance to try THEMECHANIC's .
just got done driving to Wisconsin on a 3 hour trip and it drove amazing .
Awesome! That's what we were after! Do a comparison between the file you started with and the one you ended with to see what all was changed. That way if you need to do any adjustments in the future, you will have an idea of where to start. Glad it worked out for you!
