Has anyone removed the Vats on a 2011 Camaro with a Bosch E69. Trying to make it a stand alone unit with Vats gone. Any help would be greatly appreciated.
Are all LLT's Alloytec V6's? Found a thread that shows how to disable VATS except for Alloytec V6. Also I can not find E69 Bosch anywhere on the advanced search for HPT. Any help would be greatly appreciated.
Might check the I4 threads as the Cobalt SS/TC also uses the E69 ECU. Maybe you'll find something there.
Thank you ElecTech!
Update: HP Tuners does not support E69 Bosch controllers. Also, Trifecta couldn't remove VATS unless we didn't want the automatic transmission to work. Just a guess that Trifecta writes code to block VATS but it also blocked the transmission controller. Please feel free to comment on this.
HPT version 2.25 supports E69, just no VATS.
HPTuners does support the E69, that's what's in the 2008-2012 turbo cobalt SS, solstice GXP, etc, all LNF engines.
To the best of my knowledge, HPTunders does not support VATS in the E69, which is a Bosch controller, not GM.
As you stated above, i would have said "try Trifecta" but it seems they can only do it in manual vehicles.
