5 Attachment(s)
HELP! Cant get to commanded AFR ratio under WOT, or LM2 issue?
2004 ctsv, 5.7, small smog legal cam, fast 92 mm ls6 intake, volant air intake, stock throttle body, injectors cleaned and flowed.
I went through and did VE and MAF tuning per tuning school books, everything came out cherry. Under WOT the it would run lean, can ping so bad you can hear it, never showing any knock retard though. So I move on to tuning at WOT for the MAF. I end up changing the curve so much and everytime its 20ish% off. The curve gets so high and now the car bogs. I have gone back to the point where VE and MAF are good several times and cant get to commanded in PE, or when I finally do the thing is running so fat. This one car is fighting me for the third time in 2 weeks. Same thing.
Now I am somewhat new and trying to learn so much its making me head hurt. I have street tuned this car and several others before. Again only this one fights me. We have since gotten a dyno and now I can tune on the dyno. I just had a car on the dyno, tuned through it no issues. Gets into commanded pe ratio no issues, wideband (lm2) reflects both on the screen and in scanner as the same. This car the, with the same offset settings as the last car, will show on the lm2 screen as one thing and in hptuners as something different. So I added a ground from the MPVI pro pin 5 to battery ground. Adjusted the offset to get them to match at idle and around 2k in third just holding steady. Under WOT ecm commands 12.3, lm2 screen shows around that, hptuners stays around 14.
So I fear Im fighting one issue because possible another one. Why is the lm2 not showing the same in both spots?
Attachment 53166VE and MAF tuning done
Attachment 53169Scan of above file running
Attachment 53167added more air via WOT AFR error
Attachment 53170scan of above file
Attachment 53171scan after adding lm2 ground
