Rev limit hit before Desired Limit
Guys I just got off the dyno tuning a car . The car made great power everything seemed good until we tried to rev the car a bit more. I had been reving the car to 6400 without an issue. Now that I am trying to rev it to about 6800 the car seems to be hitting the rev limit at 6450 or so. Can you guys check the tune and let me know if you see anything that could be causing it.
The only things i see is that the MAF gets maxed out. I know there is a patch for it but I believe the patch is already applied. Unfortunately I do not have a log as my computer died while trying to capture the log. Also the map is maxing out but I doubt that has anything to do with it. But I do see the Maf maxing out on the car
This is an LS2 motor original car with a crate lsx motor. I know he is using some type of lingerfilter signal changer for the crank to be able to run the car with that motor
