Holley Hi Ram - Anyone on here done a SD tune with one?
Just curious if anyone else out there has done a SD tune with one of these intakes. I really like the way it looks and the potential it has for when I go FI. It's on a stock LY6 for now. I finally got the truck running and exhaust on it to do a little tuning at idle and light revs. The VE numbers I'm getting into seem a bit high, but I've seen this with some big plenum single plane intakes too. Kinda curious what other people have seen with this intake.
Motor specs :
Stock LY6 long block
Vette accessories, aluminum ATI balancer, Edelbrock water pump
Comp 231/247 cam
Scorpion LS3 roller rockers
BRP mid-length headers, 3" collectors and true 3" dual exhaust
Holley Hi-Ram with 102mm top, LS3 throttle body
MagnaFuel ProTuner pump, 10AN feed
80lb @ 4-bar Bosch injectors - running at 40psi base, 50% scaled
Disregard the boost areas, I'm just dreaming of that part of the VE for now.
http://i213.photobucket.com/albums/c...ps5e89d38a.png
http://i213.photobucket.com/albums/c...708FB2492B.jpg
