Guys well i was going to wideband a friends car when i plug it it says SEN 1
That means that i need a new o2 sensor??
http://www.ngksparkplugs.com/pdf/AFX...ual_REV_06.pdf
it says, that it either is not attached,
the wiring is bad,
or the sensor is bad.
good luck, i hope this helps. this link shows the instructions and at the bottom will verify what i have stated. these are the same instructions that should have came with the afx. well they did with mine anyways.
$99 replacement on Amazon http://www.amazon.com/Bosch-15401-Ox...6564325&sr=8-1
Locally Autozone has them for $91 plus tax.
Since the guys behind the counter are normally clueless to get a part by part number and can only find it by year make model, ask for a front O2 sensor for a 2005 honda accord EX V6
Ryan
Autozone gives a warranty on it for a year too I believe!
