I changed the valve body (tcm) in acadia 2007 im looking if i can program it using hp tuners ?!
I don't know for sure but I do not see any way you could program a TCM without having the calibrations to begin with.. HPtuner downloads tables that you can modify and then write back.. If this is a used TCM it may be a possibility that it may start and run ok? but I am almost positive with a new one you will need to use an MDI and GM TIS to program that unit..
somebody told me you can do it using hp tuners by modifying the parameters in the transmission tables
so what do you think or i have to try ?
im using the vcm scanner (beta) i cannot use many tables like read the codes and many others a short message is 2 weeks ? what is this ? can somebody help me please
again, is it a used TCM? if so maybe?
if new, I doubt you'll be able to change tables that don't exist...
VCM Scanner beta is just that, beta.. It is not fully completed and some things aren't there yet or supported, that's what the 2 weeks means..
when it should be complete. soon ?
hey,
i want to ask if i can use the mpvi pro interface to program a new modules and ECM and TCM for all gm cars like the gm mdi and sps programming using the sae j2534 pass thru ?!
No.. it is not J2534 compliant as far as I can tell..
SPS does not recognize it..
you know if i can disalbe the vats or turned off in the camaro 2010 usiang the vcm suite ?
hey any help about how to make a backfire what i should do which tables i have to change to make a backfire in my exhaust ? retard timing ?
please any help
hey
i am tuning a 3.6 wrangler jk 2012 with penta star engine any help please how to modify the ve bank and ve bank 2 tables ?
thank you
Can you help memplease how to do this ?!
Can you help me please how to do this ?
