Originally Posted by
codename Bil Doe
For desired versus actual, understanding how the PID's control boost will eliminate the need to make desired so stupid high that it's out of reach of actual. That's putting a bandaid on a cut to fix a hole in your spleen.
The reason you don't want to do that is because the desired is a reference probably for several dozen or hundreds of other tables. You're severely skewing the whole ecu modifying it too greatly. Desired should be set above your actual goal. Then, read up and learn to adjust the PID's and other tables to avoid superceding that limit.
