The Exhaust Temp Inverse Table under Engine-Fuel-COT, Lean Cruise is missing for the 2011-2014 Ecoboost F150.
Is it possible to add the trans shift schedules for 2010 Raptor 6.2L
2010 Raptor Auto Shift Speed Tab
Attachment 67011
2011 F150 Auto Shift Speed Tab
Attachment 67012
HI Eric
Thank you very much :)
I really appreciate it.
Eldon
Is it possible we could get the Sport Shift pressure and shift schedule tables for the 13-14 Mustangs?
2011 Mustang 3.7, MAF period parameter in the scanner.
2016 Mustang GT
Scanner PID:
Is it possible to read IMRC values Open/Closed?
Transmission boost pressure per element?
TCC speed ratio?
Is the a gear shift change "actual" vs commanded PID available?
Editor:
Can traction control be disabled?
Can car be put into OP spark mode?
Hi,
I see the last responce was in 2017...
I have a issue with a 2016 Mustang that had some Whipple software on which we have to retune for additional mods. I have done this before so no issues there. Problem is some of the parameters is missing, namely Mass Airflow period. I running VCM Scammer V4.0.12 which is the latest. Attachment 83513
Hi,
Yes downloaded beta (4.1.485beta) last night but still the same.
Submit a support ticket
Hi,
5R55S tuned with sct Shows the Option Shift Pressure in Trans.
I miss this item in hpt files, that are not tuned with sct before.
Best regards
Maybe this has already been addressed in a thread somewhere. I searched high and low but maybe I just did not search in the middle.
Individual cylinder misfire pids for Fords would be great. I know the PCM is offering them as my Ford IDS/VCM2 has it, just have HPTuners up and running a LOT more often than IDS.
Hi,
a lot of parameters that are to see on the 05-11 civilian Crown Victoria and 08-11 Crown Victoria Police are not the see on the 2006 and 2007 Crown victoria Police interceptors.
They do exist (because of the behavior of the ECU on the bench) but are not in the VCM editor.
Thank you for asking us
I am not sure if anybody is monitoring this but I have a couple on EECV - 2002 Mustang GT
EECV - FUEL - GENERAL - OFFSET MULTI vs PRESSURE
The software seems to apply an additional decimal place and create a problem in the EECV when cells are entered manually or generally corrupt this table. The only way I could get the injector data entered in this table without the car going pig rich was to adjust the existing cells via the multiply box. A tip from another user in the forum. This is with being aware of the starting and ending values needing to be identical on the ford PCM as well. Somethings really off on this table.
EECV - MISSING STARTUP FUEL ENRICHMENT TABLE (fuel_table_startup_OL )
I cant find this for the life of me. It does not appear to be in the software. Can you please add it ?
Create support tickets for missing parameters. Thanks
I have an open ticket that i never received a response to. It is on a 2010 Taurus Sho, so I realize it isnt I large priority on the list. My ticket number is 161248, I submitted it back in January.
e38 6R80 - need VSS parameter to use 6th gear in higher range.
Shift tables were ignored / restricted at WOT . It doesnt shift into 6th.
