69 Camaro/ LS2 (GTO) conversion tune problem
I am new here at HP Tuners. I have installed a LS2/t56 out of a GTO in my 69 Camaro. I have been doing research on the conversion, and have used HP Tuners to turn VATS off and the 2nd set of O2 sensors so they will not report. I modified my own harness and have got the car running. I am having problems though. You can hook the battery up and start the car and it runs smooth and has great throttle response. I then switch it off and crank it the second time and it runs like crap. The throttle pedal will not actuate the throttle either. The car surges from 800 to 1200 rpm and runs very rich. I can unhook the battery for awhile and then it will crank and run smooth again until the next time it is started.
Here is my tune below. I also included my DTCs that were recorded when it while it was scanning. Maybe I am missing something.
Any help would be appreciated.
Michael
