Is a negative value in STFT indicating that it's rich and a positive number indication it's lean?
Thank you Sir!
I am told the scanner now supports DMR logging and Rapid Packet on the older Oak PCMs we support.
We have to put it through testing and find / fix any bugs that may be there.
Big news, especially for the Australian guys!
where can i download 2.25 from
I did a log today and saw negative KR reading. Am I looking at this backwards? I thought a positive number was adding spark and negative was pulling spark.
Can someone confirm that the KR is working correctly? Should I not trust the reading?
The way it worked on older Ford systems with the other guy's software is you have to think about it as Knock RETARD. So a positive number is "subtracting timing," or retarding it, and a negative number is adding timing or advancing timing. I believe that's how it's set up here but I've been waiting patiently for Eric to answer my question about it.
I did plot it against TA and thought I had it figured out. My log showed up to 8* of KR and was freaking me out since I didn't know if it was advancing or retarding. Then I plotted it against TA and it looked like some of the time is was advancing and some of the time it was retarding. All KR was positive on the log.
I backed it up with a livelink log and it showed that the KR was adding(up to 8*) and pulling spark(up to 2*). So, my conclusion is the KR is NOT working correctly in 2.25.
My last log with 2.25 had some negative KR(-1*) readings which has me confused. I turned all KR spark advance off in my tune. That's why I think KR is not working correctly.
Just did a drive log with livelink and the same tune that I logged with HPT scanner that recorded -1* of KR. Livelink showed 1* of KR(pulling timing), so from this info, I think HPT scanner is opposite Livelink. It appears -X* is retarding spark with HPT scanner and +X* is advancing spark.
I really like the scanner and I'm learning all I can about it, but if KR is not working correctly, I need to know.
Can someone from HPT please confirm or deny this?
Does the copperhead OS FSFD1AA.H32 have all the PIDs added? I'm not seeing any fuel pump, pressure, and injectors PIDs showing any data. Also, is there a way to export the log to CSV that I could analyze using MegaLogViewerHD? Thank you.
Will injector pulse width be added soon? Sure would like to check my injector duty cycle. (for Ford 2013 GT500)
Leave it the way it is if a negative number is truly retarding timing
FPDLA5A2...no maf period no mapped points.
