Trying to make sense of this
I am trying figure out exactly what is happening on this car. I made a config to log all the spark I could find that seemed relevant, plus some that probably were not. I was also logged Dynamic Airflow and the Default MAF (SAE) I noticed these #s were close but never the same at the same time. which/if either is a representation of actual Airflow into the motor and which is from the MAF Calibration.
After a few little changes to spark(Set HO, LO, and Base Idle to 23 in idle area) and Base Running Airflow(added 4g/sec 2 at a time, up to 1200 rpm) started the car, it started without pedal assistance, reved itself to about 2k and came down very slowly to set idle. After 30 secs or so it started surging again,(scan log frames 300-1000) I reved it off idle for a few seconds then let it idle, and it sat and idled fine, turned ac on, still idled fine, put in gear, idled fine. Turned car off and let sit. Re started and did the same surging after about 10-30 secs of run time. After reving it up a little seems to be fine. The car drives fine, and have no issues on the street, just dont like that the idle is pick when you first start it. There has to be a way to fix it. I am not looking for hand outs, just some one to point me in the right direction. I have read tons of idle setting procedures here, but after trying most, I am still coming to the same result. Any thing would be greatly appreciated.
