I know it's stupid...
But the manual transmission cars can rev @ 5700.
Where can I disable the rev limitor @ 4000 ???
I can't find it in hp tuners
Maybe post the file you are working with, There are about 7-10 different V6 pcm's we cover all of which use different strategies.
great!
it's a 98 V6 3.8 Camaro
Here is the tune
I've tuned it yesterday (transmission, !cot, !egr, !governor)
I've tuned the VE table using LTFT. 0-1%
(no wideband in my friend's car... the wideband is on my c5)
I want to do it in another camaro (99)
maybe we can make a sticky with all the possible strategies for the different years / model !
(I'm interessed to do it to C5 too)
I'm learning everyday !
Your product is great !!!:yay:
We don't want to do it... becuase it *is* stupid (lol).
It is real easy to spin the bearings on an engine that hits high RPMs with no load. Thats why GM put that limiter in there for us... to prevent those that are not too bright from damaging their engine.
with my mn6 I can rev still 6000 rpm... it's stupid , but I'm doing it twice a year ... for exhaust video for example.Quote:
Originally Posted by JerryH
So it's hard to compare with auto transmission
By the way, I'm learning hp tuners, and I want to know where I can tune it...
Engine-Fuel Control-Fuel Cutoff.
great! thanx !
how can I make my Silverado pass 98 ??? thanks in advance :worship:
Your question makes no sense.
Re: PASSING 98MPH - You should be using HPT in "Advanced Mode" under View. Then look for speed limiters in your Engine and Transmission, and Speedo sections. You should also check out areas related to Torque Management & Abuse modes for even more limiters in some cases. You can also post for help with this vehicle in the V8 section as they are very used to your PCM & transmission over there.
If his silverado has a aluminum driveshaft I highly suggest not removing the limiter, the factory shaft can and will explode at speed above 100mph.
