1 Attachment(s)
I cannot seem to find the MAF airflow vs. Period Table in this file
Quote:
Originally Posted by
bravo685
Use the MAF Airflow vs. Period table for tuning. Yes the table is upside down. Just pay attention to the right side column marked AIRFLOW. It's in #/min and on a stock vehicle ranges from 0 - 68.
You will need a scan tool to check the short term trims but can quickly tune the MAF by holding the car on the dyno in 4 - 6 places in rpm starting with idle and getting an average trim and applying it to the whole table for starters. Then go back and set the table in specific locations. IF the trims are max'd out then you will have to do the first step again. Make sure the engine is at temp or you'll be chasing your tail. AND... change everything else back
Steeda MAF lb/min (stock intake/throttle body)
1485 0
650 0.473800003528595
635 0.501399993896484
605 0.541649997234344
590 0.568099975585938
540 0.666999995708466
500 0.770500004291534
450 0.983250021934509
410 1.19599997997284
360 1.70200002193451
330 2.16199994087219
320 2.29999995231628
290 3.01299977302551
275 3.51899981498718
259 4.08249998092651
242 4.8299994468689
226 5.8597674369812
220 6.29645681381226
215.5 6.55772542953491
210 7.01546001434326
207 7.2883620262146
200 7.90578413009644
193 8.74631977081299
188 9.25332164764404
183.5 9.88822269439697
178 10.9280033111572
173 11.9484996795654
160.5 14.9499998092651
150 18.8599987030029
143.5 20.6999988555908
139 22.5806865692139
136 24.0044193267822
132 26.3388404846191
128 29.5371055603027
123 32.9985122680664
119.8 34.890998840332
114 39.9280014038086
107 47.5375518798828
101 55.3034973144531
83.3 78.1999969482422
