Check them first. Hopefully this helps someone. I have some others as well.
Attachment 80385
Attachment 80386
Attachment 80387
Attachment 80388
Attachment 80392
Attachment 80393
Attachment 80394
Attachment 80395
Attachment 80396
Attachment 80397
Attachment 80385
Attachment 80386
Attachment 80387
Attachment 80388
Attachment 80392
Attachment 80393
Attachment 80394
Attachment 80395
Attachment 80396
Attachment 80397
Looking for a 2010 CTS-V stock file if someone has one.
SIMPLE Tune Library replacement, anyone want to help me finish?
https://docs.google.com/spreadsheets...it?usp=sharing
NOTE: LINK FIXED!
I have collected over 100 tunes to add to this list, the download link is to the far right of the spreadsheet.
I am needing a 2007 Savana Van 6.0 4L80e Stock file.
My current project is:
2005 Silverado 2wd
Original equipped with 5.3 4L60e
Swapped a 6.0 and drove for approximately a year, without issues or codes.
Just today, swapped a 4L80e (new flexplate, spacer, bolts, new ISS wiring to pin 22 and pin23, engine harness to Transmission connector pin U (brown) to pin S (white) and white wire stowed). I completed the rebuild and added the entire HD2 shift kit. The conversion went smoothly, built a crossmember for the 4L80e, used a conversion universal joint, and installed a used dipstick. The transmission was brought to level and the truck popped codes:
P0740- Torque Converter Clutch Solenoid Circuit/ Open
P0785-Shift/ Timing Solenoid
By the way, I am prepping for boost (GT45 turbo)
I used a 2003 K2500 Sierra 6.0 4L80e stock file, for the transmission changes.
I am not sure if the 4L80e 4wd file is causing the codes, as the swap is a 4L80e 2wd?
you can email me the tunes, or if you are handy with spreadsheets and want to add the data yourself, I'm looking for a couple people to help me. I can share this sheet with a few people to do editing as long as we keep it neat and simple.
Thanks, Brad. [email protected] , Just put "TUNE for Library" in subject line.
I'm good to help out with way. let me know what you want to do
[email protected]
anyone got a stock tune for a 2015 holden caprice l77?
looking for a tune 2008 chevy express van 4.8/4l80e for segemnt swap
ecm 12617631
tcm 24239927
any help? Much APPRECIATED
Looking for a stock 1998 Corvette 5.7/4L60e file
Anyone have a 2009 Silverado 4.8/4l75e stock tune?
Tune repository is back up and mostly functional, though you currently cannot upload files to it.
