When you say "not working" what do you mean? What is it doing? What does the EGR voltage PID show?
No idea on the F-body EGR pin.
the egr position voltage pid shows nothing. i have egr enabled on editor and i brought up the EGR controls on the scanner and manually turned them on... still nothing.
on the table where the EGR / Wideband should be it shows 'undefiened pereimeter' or something along the lines of that, but only once its connected and scanning
everywhere i read it said pin 47
Are you suppose to hook it to the 5v reference for the EGR or the EGR position signal wire?
i changed to pin 55 and still no luck im using function
([PID.2810]/.5)+10
and ive tried this function as well ([PID.2811]/.5)+9.8
still no luck :(
EGR position signal AND sensor ground, not 5 volt reference...thats an output from your PCM...2 wires must be hooked up...at least that's how I've had to hook mine up (my NGK AFX has a 0-5 volt and a ground reference to wire in).
I have my 99 FSM in the trunk of my car actually...but I will try to remember to grab it and look up the correct pins again to be absolutely certain tomorrow for you if I can.
I have OCD so I just went out and checked...pin 47 is the 5 volt reference wire, think of it as an output...GM is using it to power the sensor...pin 55 is the input...this goes to your wideband O2 controller's 0-5 volt output, and I believe I was mistaken about the ground...it's pin 41...the PCM needs to see the voltage differential between the ground the the input...voltage is like pressure...you can't measure it unless you reference it to something else...and in this case, you need to reference it to the ground...so if that ground pin is not hooked up, you'll probably continue to see 0 volts on the input.
...and this corroborates my FSM http://ls1tech.com/forums/11682954-post2.html
...and you need PID.2811 not 2810
okay thanks for the help, so i do need pin 47?
ok so only pin 55,do u if u have to ground that signal wire going to the wideband?
Dude what? LOL
I know the signal wire going from the wideband needs to hook to PIN 55. But in your previous post you said something about the EGR having a pin pistion, a 5v REF, and a ground.
I assumed the ground on the EGR needed to be grounded as well. Not trying to pick a fight but if your gonna give advice on a forum have patience for those not as smart as you.
How many wires does your wideband controller have? It should get ignition power, chassis ground, 5 volt out and sensor ground. Sensor ground to pin 41, otherwise the pcm can't see the voltage differential from the other wire that you put on pin 55.
it has two signal wires coming out of it a white and a black. currently i have the white going to pin 55
What wideband controller is it?
i got it hooked up guys thanks again. it seems to be off by .2-.4 from what the gauge is reading and from what hptuners is. should i play with the last variable in the function, like change the 10 to 9.8?
