They have the refernce PRE supercharger? Thats stupid, I didnt notice. I sent you a PM a while back i think, have an email address i can bounce a couple questions off you concerning these things
That's correct, roush vmp... info at hd-customs.pl
I don't see negative ETC vacuum for the TB model helping partial throttle FI setups, or anything. MAF is positive, RPM is positive, Effective area is positive. You can't get a negative pressure from those, so even if you could enter it into the axis it wouldn't get to a negative value. Then the only way you could achieve it you would have to make the intake manifold filling model flow much worst than the actual intake tubing, and thats just so far from reality I don't see it making things better.
vct modes are based on baro. Mapped points are based on vct. Having baro fluctuate as much as the pre TB intake can would cause havoc with everything. You would want a dedicated pressure sensor and modify ecu code for it like Ford did with cars that use TIP or SIP sensors.
Emailed you Caniggia. Found two 1/8 NPT plugs on blower in inlet runner, which line to the bypass on the roush blower shoudl be moved there? One is in the TB neck, and one looks like its above the rotor group but more in the plenum?
You can do that but depending on the OSID, you might be missing some things you need. e.g: many of the NA OSIDs do not have the IAT2 PID active. On some of the earlier OSIDs, you might have to splice into the unused pins on the ECU to enable it. It really depends on what OSID you have. What year is the ECU and which OSID?
Just an FYI you should be able to do it, I believe theres like 2 or 3 pids that need to be logged for the graphs to work properly, if you are missing any of the pids its as simple as emailing support. My operating system was missing them and Eric added them for me pretty quickly.
it's working since long time, awesome:)
Hey guys, this subject is very interesting to me. I have a 2012 Mustang with an M122 blower and Department of Boost manifold. Lund has been remote tuning the combination, but we have gone in circles on a few things. Part throttle response is one of them. (Decel richness being the other nagging issue)
Here is a log where I tried to roll on the pedal as linearly as I could:
ETC in purple, Pedal in brown, MAF rate in blue. I drew in what I think would be a better MAF curve (in green). Having MAF track linearly with pedal, should give a more predictable feel.
Attachment 78055
It is a bit better now. I think that they lowered the WOT start point to fill in that big void in the ETC opening rate. I still think it can be improved. I also made a small orifice to install in the bypass valve vacuum line. I started with a 0.065" orifice, and now have a 0.040" in place. It definitely softens the transition into boost, by slowing the rate of bypass valve movement. I have a mechanical boost gauge which helps show the effect.
My VCM Suite should arrive tomorrow. So I am eager to dig in and improve this. As a former superbike racer, I am pretty particular about my throttle response.
i am working on coyote 2012 centri SC app. In scanner i can't find ETC vacuum. i am using beta letest version. any help
Hi there guys , I have a customers 2010 ford mustang with a Edelbrock supercharger fitted to it and running the 82mm throttle body and car runs good and when bad fault code P061b , Need help to fix this fault .
