Originally Posted by
schpenxel
So I was messing with an E38, hit edit, add slave segment data. Saved, re-opened. There's now P1516 error parameters in engine diag-->airflow section.
Is the idea we just increase these as needed and do a write entire?
I tried the same on an E40 but there isn't an "add slave segment data" option in the edit menu. However, P2101 shows up in the same place as P1516 showed up on the E38 and basically has the same description.
So, will changing this/writing entire increase the tolerances accordingly? Then I can edit the throttle map tables..?
Probably a dumb question and I should just go try it--but I really hate dealing with reduced power errors on the side of the road if I can avoid them so I'd rather ask and see first..
