I sent the .cax files the efilive guys are using to hptuners support in reference to the issue Im having. we'll see if they can get it done, or if they'll push it off on me to use the user defined parameters
I does sound like a good start. Unfortunately, that is where my search is stalled. There is literally just the one post and a reply saying thanks, no actual discussion on how the individual used the table. Not much talk anywhere else either and as I mentioned, not defined in HPT that I have seen. It could also be a table that specific OS's just do not use. So, back to patents to help understand what direction GM was going with their transmission calibrations.
Yes, you can use user defined parameters with HPTuners. Yes, more people to need explore and discuss user defined parameters. You have to pay for it, HPT limits the areas you're allowed to edit, and you'll need to know how hex addressing works amongst other things. (I think HPT also does a hex-to-decimal conversion when loading in xdfs but changes based on the units you have your software set to display by default. This is not documented in their official post or anywhere else and it is annoying.) Definitely dust off the EFI stuff, sometimes they have things defined that HPT does not. That is where I would start since the work is done already, then move to xdfs. For the xdfs you need to understand that an xdf is specific to the OS it was created for. You can download tunerpro rt5. It is free but you'll get a nag screen when you open the program. You will need .bin files for use in tunerpro as well. I doubt HPT will be adding any tables to anything older than Gen4/5 at this point. Anything that old usually ends up with a standalone/piggyback setup once specific issues like this arise, so not much incentive for HPT to update anything. If you send anything to HPT you'll have to "show your own work". I don't think they'll just take an EFI file and run with it, or they will... I don't know.
PCM Hammer and LsDroid are the most user friendly options I know of. They will read the PCM and let you save it as a .bin file.
Just bored at work, but I found a .bin file for my year/model truck with the same OS. Can I download that, use that in tunerpro to create the XDF or whatever I need to establish a user defined parameter for my tune? Or do I have to do all this specifically using my truck?s bin file?
If it is the same OS it should work. Now, creating the xdf for that OS is by no means a "click the button" procedure.
Right, I?m just trying to avoid having to buy another interface and download yet another program to fix this issue. If I can use the bin file I found to setup the XDF, configure a user defined parameter and get it set up during downtime at work, I can hopefully test and resolve the issue this evening.
Well, it's probably in the .bin but you need an XDF with the table defined for your specific OS to correctly display the data within the .bin. For example, you have OS 12619623. You need a .bin for OS 12619623 and a XDF specifically(and correctly) made for OS 12619623.
I noticed it labeled D1110 in the 12587603 xdf but in EFI, D1110 is a different table, if it is defined. I have not seen this specific RPM Drop ratio table defined in any commercial tuning software yet. So no, you probably wont see it in EFI/HPT.
The D1111 table is in the two xdfs I posted links to in this thread. For example, one of the XDFs was specifically made for OS 12587604. In order to use anything in that XDF, you need a .bin file for OS 12587604 (2004 GTO).
I?ve made contact with the guy that posted that .cax file on the efilive forums. We?re discussing it. I?ve also played around with different files and think I?m on to something. It may take a combination of efilive, hpt and tunerpro, but it will be worth it.
I am trying to follow this but I am lost. If you could, point me to some literature that could explain what is going on here. Thanks guys
There isnt really a "how to" or anything on this. What it boils down to, EFILive has an option for users to create their own parameters if they know the specifics of the parameter they want to adjust. EFILive calls these .CAX files. Hptuners offers something similar with their "User Defined Parameters". There is a fellow who uses EFILive that has figured out the parameter we want to adjust, however efilive's process of defining a parameter is much different than hpt, obviously. You have to use TunerPro to create an .XDF file to import into hptuners in order to use the user defined parameters. XDF files can be created in TunerPro, IF you have a .bin file for your tune/os. .bin files are essentially the raw data on your PCM, hptuners interprets that and presents it as tables, graphs and parameters. Now here's where things get complicated, for me anyways. Your .bin file and .XDF files have to match OS wise, and my particular OS is not one that someone has already defined or shared an .XDF file for. So I cannot simply download an .XDF someone has already created and graciously shared, make the changes and run with it. I'm going to have to define an .XDF for my OS.
Looks like your OS is supported by Universal Patcher. https://universalpatcher.net/ That program can spit out an xdf for you and it works with user defined parameters in HPT. You still need to load a .bin file into the program for it to work and the RPM Drop table is not defined. (There are two stock .bins for your OS you can download here.)
I also attached a xdf for the RPM Drop ratio table for your OS. There is a second larger table in there that can be ignored, I just used it try and see where things were located. Use at your own risk, I have not tested anything so no guarantees from me.
On another note, what are you theories for adjusting it? Manipulating the start column, end column, or both?? I emailed the guy that posted the solution on efilive?s forum to see if he could/help and discuss, and I guess he thinks I work for HPT and has said he will not help 🤷🏻
I have no idea and have no way to test unless I can find similar stuff for a T42. And I am just assuming there will be similar stuff used in a T42 since it essentially controls the same transmission.
I was hoping the person you contacted would be able to give some insight into how it works. Probably has some resentment towards HPT. They probably "borrowed" something of theirs from EFI back in the day, who knows. Not sure why that has to effect us normies...
I replied and told him I was in no way affiliated with hpt, just a guy trying to figure out an issue and would only share his info with those in this thread, but he just replied “LOL”
