Connecting your wideband linky HERE
Also in the help file (Press F1) under Scanner/Enhanced IO
can you directly connect a wideband sensor to the MPVI PRO? Can you log 2 wideband sensors at once? so you could read both banks?
yes...yes....
up to 4 devices at the same time using a 0~5 volt output
Thankyou sir !:hi:Quote:
Originally Posted by EC_Tune
Here's another one I ran across last night while searching for info about widebands and how temperature of operation and exhaust backpressure affect them.
Western Motorsports
Dual Innovate Motorsports LC-1's
Both Permament install, simulating Stock O2 outputs. Heater Performance DTC's turned off for front O2's. Rear O2 codes disabled.
Works real nice, but i managed to fry one of the DAC's (my fault not the cable, sparks are evil! :P)
LM-1, had it for a few years now, just about to try connecting it to the EIO cable to see how that works.
Back from the dead. Nothing like a first post resurrection!:hi:
Wondering if anyone is using the NGK fx wideband? I hade one on my Talon with inputs to DSMlink. Worked great and I had it permenatly installed. If not then whats the latest and greatest for perminate install and narrowband imulation for HPtuners? Just searching it looks like AEM?
Just got my PLX SM-afr with DM-200 60mm oled display. <3 . Very nice unit, super easy to piece it together and no calibration. About to get into the custom displays so I can make the guage look factory.
Really like the Data log screen, it helps when you need to look away from the AF and look back you can know where the ranges were.
i got a AEM it works good. seems to be acurate, just not instant.
but close enough.
PLX SM-AFR controller with PLX (Bosch) wideband sensor.
PLX DM-100 OLED gauge and controller. DM-100 gauge is programmable and configurable to report Boost, EGT, AFR, and other supported PLX controllers.
PLX controller is replacing the stock narrowband signal through the stock connector, and heater is simulated with 2 10ohm resistors:
http://i20.photobucket.com/albums/b2...O2Resistor.jpg
Wideband output from controller is wired into HPT Pro with quick disconnects.
I've been running this setup for about 7 months now.
I got a PLX AFR and I'm going to probably return it (if they'll take it). It reads 15-16.5 when my narrowbands are flipping back and forth nicely. Waste of $200.
I've got an LC1, worked good for maybe a month and then started acting up so sent it out to innovate.:mad:
AEM here. PID offset needed 9.6. Works great now
