They are in the Dynamic tab....please look at my post #36 above. I showed you where all the tabs were.
Ed M
I see its under the dynamic tab for other vehicles, not mine, so now what?
ok got it to show now. for some reason it only showed the first 2 boxes
it wont let me right click on the tab
that's what im clicking on
Are you seeing this....
Attachment 42785
ok got it imported after 2 trys and a .net issue. it does keep closing vcm editor. now which table format? ls3 2.5bar?
Yes.
I have problems with shutting down the VCM as well at times. When that happens you can leave the BC Equation screen open (don't hit import) and copy/paste each of the tables from the tune file manually.
OK looks like you got it imported and the VE table generated. This represent the "Primary VE" table that the Tuning School talks about. At the bottom of the table is the MAP and RPM axis values to put in your histogram.
Ed M
ok working on the histogram
http://i885.photobucket.com/albums/a...pscacb8af3.jpg
ok its not creating the histogram. does this look right?
It is better to use the PID's instead of the sensors, more accurate. Use the RPM and MAP PIDS similar to how you selected the sensor ones. Don't forget you gave to generate an AFR error PID to load into the General & Plot. Lastly make sure you have selected all the required PID's into you .cfg file. Includes the sub pids needed to calculate your AFR error.
Ed M
http://i885.photobucket.com/albums/a...psaeb76461.jpg
ok changed to pids, still not accepting it
what did you input in the General & plot tab?
nothing because it said to leave the primary blank
