There is an adder modifier table that lets you adjust TM via a given RPM. Makes for a really slick tune. It allows for full TM in areas or no TM in others.
Well it's been a while since i made posts in this thread, i've actually tuned the TM adders from my previous tune, to not have TM during the shifts at WOT. did it as test to see if the 3-4 delay i was having at the track was the result of TM and too little shift speed time. i'm pretty much using stock shift times now, and using the TM adders to have 50% at low/mid throttle, and 0 tm for WOT upshifts. this way i barely spin the tires during the WOT shift, and i still experience the confort of the trans without having to snap my neck at crusing speed. i've been running like this for about 3 months, and so far i like the results. i'm sure my trans won't last as much as GM designed it for, but i'm also not racing the car every weekend at the track, so i feel confortable with my settings.
And btw, TM had no bearings in the 3-4 delay.
What ever happened to bluecat's info on this thread?
It's been proven TM is a good thing for the trans, look at how many people are rebuilding 6l80e's, what do they have in common ? they didn't have TM :)
Btw, i went back to my 10-12% TM at WOT, only ran it at 0 TM for 3 months and one week, I see no point having 0 TM unless you want it, really. I just wanted to try for myself and see the difference, in my case, it made no difference how the car ran other than my brain telling me she was faster because she was running zero TM. I guess if you have an all out drag car, it would be one thing, i bash this mine almost on daily basis, i still want some nanies to watch over my clutches, almost 80k miles here, driven like i stoler her pretty much on daliy basis, and i haven't touched the seals on the trans, just a fluid/filter and trans pan change at 70k miles to accomodate my yank 3200.
I pm'd a very well known calibrator that worked the manufacturers at one time and he said tm is your friend, and will definitely extend the life of the trans. I want to go back to running some. The one thing I noticed when I added some tm back in is that when tm was enabled, it sounded crappy between shifts, like a very weird exhaust note. Didn't like it at all. Must be a setting I have in there. How do you like your stall bluegoat06? I am kicking around doing a 278 mm 2800 from Circle D, but don't want to mod further if I can't get the current issues ironed out.
One of best mods i've done so far, next would be a cam, something like a 228/232 or 232/236, still not decided, TM can be customized per shift and requested torque, so she doesn't run full TM in between shifts at part throttle or WOT. The converter made the car a lot more fun to drive.
I'm intently lurking this thread... less for performance reasons, and more because I can't stand the way my 2012 Silverado shifts....
Would adjusting the TM help the tranny find it's gears a bit better? I feel my truck hunts far too much between gears. I didn't buy a truck for fuel economy.
I hate to say it, but you'll need to play with TM to find what you like your shifts to be. start with 50% for the low/mid throttle area and see if you like the shifts, lean that TM out the closer to WOT you get, for less TM during WOT shifts. i have mine setup at 50% TM for parth throttle, and depending on engine requested torque and RPM, i remove more TM, until 10% is left for the WOT shift, i do this for WOT 1-2,2-3 and 3-4, 5th and 6th have 100%TM during WOT shifts, the rest is 50% TM for anything other than WOT.
Yes, you'll have new shift points at WOT so this would need adjustment, you need to bump the tcc offset so the verter locks tight when the tcm commands locking pressure, you'll need to zero out desired slip in all gears, and disable WOT lockup, you only want lockup at part throttle, we're all doing 5th and 6th only. I'm lazy to type everything again and post print screens, but i made a thread in my local forum, G8boarddotcom, tuning section, on what you need to change, thanks to everybody in this forum involved one way or the other.
Good Read. Not sure how I missed this thread. I find that you can get away with turning TM off when using stock shift pressures and main line pressures, but the second you up the pressures to handle increases in hp, from modding, TM is needed, esp part throttle....unless you want to slow down shift times...ie introduce more slip.
Kind if seems like a no brainer, but I don't tear them down and measure clutches, so it's just speculation.
I tune tm for each gear separately, in each rpm range, and have had good results so far.
BmB
I don't believe this to be correct at all. TM does not introduce slip, it just pulls timing.
I agree with what Waker posted here: http://www.hptuners.com/forum/showpo...0&postcount=34
Newbie question...
What does increasing the MAF voltage do to the delivered TQ & hence the shifting with TQ/Mgmnt on?
Kind of an odd question but "the tuning school" 6L80e tuning guide says to change a lot of stuff dealing with max pressure and the tq settings (that disable tm)
Kind of confused how a tuning school says to pull TM but most good tuners say dont?
ken, check out the "how did you get started" thread on pt.net
simple reasoning
