what all is configured on this?
Bill, Im a newbe here and I thaught I could use the Interface alone in the Car to do some logging. When I plugged it into the LAPTOP there was nothing there.
It has a record button on it and a stop. I thaught this was for stand alone logging. Also was it wise to go ahead and license the two credits so soon since it was my own car ?
It is for stand alone logging, but you have to configure it with what to log first. There isn't enough bandwidth in the OBDII system to be able to log everything at once so it has to be configured to log what you need at the time.
First you need to set up what you want to log in the the VCM Scanner then go to Scan>MVPI Pro Data Logging, then click the "Write Config" button.
Keep reading there is a lot to learn.
Hello
Please I need emergency a stock tune file for 2009 cadillac CTS 6.2 V8 Supercharge Manula Trans.
Thanks...
log onto you account on the main hpt website. there is a link there for the repository.
http://www.hptuners.com/
I cant seem to get hptuners to monitor Manifold Vacuum on my 2006 gto.
G8GT Config File
hey guys i cant get the maf air error histogram to work,am using aem wideband.
G8GT Config file, AEM WB, configured to Display Lambda, at 14.68afr per PCM Stoich AFR.
I need a 06 SSR E40 config, and histo file please. Or will one of the ones here work? I can easily change PID,s I just want it to say 06 SSR instead of 2002 camaro!!
Somebody should clean the crap out of this thread to make it sticky worthy
i tune a customer camaro to 13.3:1 air fuel at low load with a g6x3 cam
and 12.8 wot this is my configuration for a open loop speed density tune 100 in air fuel error equal 0 percent
90 equal -10 percent 110 equal + 10 percent
100*([SENS.120]/13.3) for 13.3 air fuel
100*([SENS.120]/12.8) for 12.8 air fuel
I am having a really hard time logging MAF with my NGK AFX through the a/c preasure switch. With a E40 any sujections Bill?
Is this the proper setup to tune the MAF? Posted config file, histo file, and tune file.
sorry here are the attachments. I tried lots of different things before arriving at these, I think these are right?
How long should I drive, what type of driving should I do to get the best results from these?
At the end of the log to I just leave the log open high lite the entire maf table, right click, copy. Then open up Hp editor and go to the Maf lo table high lite the whole thing copy paste special % save up load. and relog to confirm?
Attached updated Tune file. I also disabled DFCO and CFCO. In summarry I disabled VE table, STFT LTFT, DFCO, CFCO, and Cat over temp protection
Does anyone have histograms for BETA scanner? None of mine will work now that I have beta.
