redownload it lol the file should be ~23.5mb in size...make sure its no smaller then that basically. Im sure their servers are getting their asses kicked right about now though.Quote:
Originally Posted by bestes125
hi all
i guess this question is for the moderators? just downloaded 2.1.14. looks great. i have noticed that in my editor for my ls1 that there are simpler parameters in my sd operating system. question am i going to have to do a write entire since the format changed, or when i do my next write cal, will the changes go into effect? thanks again for the great product and awesome up grade
No need for write entire. The file structure and layout has changed. When you save your file, it will be saved with the new file structure.
EC
Duh!:doh: Knew I didn't click on everything, lol!Quote:
Originally Posted by foff667
thanks EC_Tune. i just love this, much more simple for me now. to bad i am going to put my car away at the end of the month lol:o . thanks for the quick reply.
eric
So whats going to be under the new SD TAB? he he ........
The new trans layout is WAY better. Nice work!
SD for the 2006 E38 ECM's...
Got it, thanks guys!
http://www.clicksmilies.com/s0105/tr...smiley-043.gif
Still only for gm.....
Quote:
Originally Posted by mulot30th
I second that question???
-yesQuote:
And not for LS2's..
[Grumble]*grumble grumble* still no Ion 2.2L ecotec *grumble grumble*[/Grumble]:banghead:
No RTT for a 2002 LS6 yet either then?
Should be. You can find out in the editor, just open up your file and go to the Operating System form.
Nope, it says '2-bar MAP - Speed Density', but no (RTT) beside it...If you are the owner of HP Tuners, is there a chance you can check to see if there is indeed no RTT for a 2002 LS6 (z06), or if I'm just doing something wrong? I would sincerely appreciate it. Thank you sir.Quote:
Originally Posted by Keith@HPTuners
fwiw im looking at an 02 Zo6 file right now...OS #12221588 & RTT is enabled for 1/2/3 bar SD & 1 bar maf :shrug: post your file if you don't mind, but it should be there. If not be sure your updated to version 2.1.14
Its all based on operating system, not vehicle year/model.
yeah i know ;) its also possible that he somehow didnt install .14 though...just covering all bases which is why I asked for him to post the file so we could see.Quote:
