Thank you. Thank you. This will be very helpful.
If anyone can get a read on PP2 or PP3 that use the GT350 throttle body, that would be great. :)
This is awesome, just in time for my Whipple install and first tuning attempt at the s550. Nice work guys.
Has anyone got a Ford Motorsport tune? Very keen to compare it to what we have developed in our cars.
looking for a S550 Roush/Ford Racing Supercharger read...
can someone share?
Be careful with this one. I can't guarantee that it is completely stock.
Attachment 69177
Yes. But you must use the Beta.
One thing that would be very helpful would be if anyone has a Whipple setup and can post up a copy of the calibration with the power by gear tweaked with their Flare Tool so we can see just how the engineers cut down on the boost/power. I am sure I can figure it out through trial and error but would be nice to see it from a calibration that is up and working.
Also has anyone successfully flashed a standard 2015+ PCM with an import of the Whipple settings and had it work properly?
My concern is any tables or bits added by Whipple/Ford in the new OS that isn't in my current PCM, and therefore I wont be copying those into my PCM and will face some issues.
Eric is working on some of this ^^^ I sent him many different versions of the tune with changes and none of the changes show up in the tune - hoping it can be done in the scanner as it's just like resetting fuel trims when you change these settings - otherwise may be fighting an uphill battle ;) I can post the tune with some changes, but if Eric couldn't see them - not sure anyone else will be able to?
Here's a version of the whipple tune with tq reduction for the gears...
Great stuff, hope Eric figures it out. Question I have though....if say someone is using a Flare tool, then scans, makes some changes, and reuploads the new tune via HP Tuners does it reset what was changed by the Flare tool? I am considering buying the Flare tool just to have the various niceties of torque reductions, etc, but be able to tweak the Whipple tune for my larger injectors, triple fuel pumps, etc.
Nope, because that is exactly how I'm tuning them at the moment :) Use the flare tool or rather the ford racing communication tool that whipple put their name on to make changes to gear ratio and disable the limits and then using HPT's to make changes to the tunes ;) You can even re-plug the flare tool back into the vehicle and see the settings weren't changed as they are automatically re-polled for their settings...
The fact that the tune doesn't change these settings is why I've been pushing so hard for it to get added and trying to help HPT figure it out... Without being able to change these parameters almost makes being able to alter the tune null and void... These parameters in their stock form WILL shut the cars down if pushed hard for more than a couple of minutes...
Since gear ratio and tire size are in with this - I'm all but certain HPT can incorporate these settings into the scanner - especially since that's how we have to adjust tire size and ratio right now with HPT...
Eric and the guys at HPT have their hands full right now "possibly even an understatement" and are currently still adding in the different Ford Racing OS's - they change the OS's every time they make a change to the tune, so unfortunately lots of them to get added in :) Then they have to get the scanner to work with all of them, so lot's of work for them :/
Are you speaking about the Ford Performance/Roush supercharger calibrations, Power Pack 1-2-3 calibrations or the Whipple calibrations? I took the announcement to mean that if you have flashed your PCM with any of the FP Pro-Cal files you can now change the parameters in Ford's cal files...
It's actually one and the same, the Whipple tool also flashes a very similar Ford Racing type of calibration, while not identical the beta VCM can read them.
I noticed the Driver Demand tables in the Roush/Whipple files are 40%+ higher than stock. I don't understand why as the car would be un-driveable.
Hopefully someone can chime in on this as I'm working on a Whipple car, remotely, right now.
We swapped the pulley on the car and it's making around 14 psi now. I'm getting a throttle closure right around 3500 RPM. It looks like I'm exceeding a torque or load value, but everything I can see is adjusted well outside the range. I confirmed with the shop that built the car that the Whipple cal that they read and sent me was loaded with the Flare limiters enabled. So, I'm guessing from reading the previous posts, that I need them to flash the car with the Flare tool again, but this time with all the limiters disabled? Does anyone know if thus means I'll need to license the file again?
