You can send the PCM and I can disable it.
PM Sent sir.
Thank you!
Eric,
I have a coyote and PCM out of a 2014 F-150 I'm swapping into a supercoupe. I also have the mt82 6spd from a 2014 mustang as well going in it.
What would you charge me? If you want to keep it private you can shoot me back an email [email protected]
Hello
Swapping 5.0 to 67. Won't start without cluster. Can you fix that?
needs to be sent to eric, I would recommend contacting him directly.
Realizing this thread started in 2015, inquiring if a solution to the PATS issue was ever resolved, I have been following the roush and ffrp supercharged strategy and the ability to write entire to a naturally aspirated PCM. If we have a FFRP control pack strategy, which from what I understand has the PATS hardcoded out of the strategy, will that resolve the PATS issue, or is this in the VID block?
Does this still require sending the PCM to Eric or can it be done via VCM/Scanner?
Hi Eric, Can you still do these, I tried PM but your inbox is full,
Are you able to email me [email protected]
Any new info on this… working with a used car dealer, original ECM was tuned with a SCT, so we had to use another ECM, when I wrote tune and turn off PATS, everything is dead…17 model f150
I am still doing PATS. I'll PM you
I?d be interested as well please pm me
Can you please pm me I need to get PATS DELETED 2016 f150 with 3.5 turbo, thank you.
I have been trying to get in touch with Eric about trying to get some PATS deleted on a 2013. How can I get in touch?
