Digging up some old emails here. Let me know if any of this is helpful
I cannot use a e38, I have to switch to a e67, the e38, doesn't use gm class 2 data, that the Colorado runs on. Factory Gauges, ac, abs, all freak out and won't work with a can only pcm like the e38. I have good used e67s in stock. It's easier to do a new harness, then two use the old ones. Because the e38, is in a different location then the e67 will be. For the Colorados from 2004-2007, you need to solder on or butt connect and heat shrink a e67 pig tail I provide, or I can make a custom resin cast adapter that goes into the original p12 pcm plug, and has a e67 j1 blue plug on it. Also you need to run two can wires into the obd 2 port that I provide. Trucks from 2008-12 are plug and play!
Stock Colorado, pedal ignition , switch, cluster, ac, abs, etc.. all function as stock with a e67:) you will need a Colorado v8 09-12 base tune 09 had no vvt, 10-12 had vvt. I can provide gm sps flash to base os, and a 4l80e tcm os. You need a t42 tcm, which would be in your van I can program that to work.
I need to have the pcm, and tcm, I sps them both to gm Colorado vin with 4l60e, that way they pair togeather properly, then I reflash the tcm with a 2009 4l80e with the e67, on Board, then it mates the 4l80 tcm to the e67 pcm. Then I use efi to flash in the same vin to both modules.
I will program with gm ‘‘tis to 2010 5.3l vvt, and 2009 4l80e tcm, it will run with just a security learn, and fuel pump module delete. But will need a tune after leak checks are done etc. I can’t tune for the 6.0l, but I can setup the injectors, delete the fuel pump flow module, setup the fuel gauge, and e-fan, tire and axle size, and turn off certain dtcs. That will be enough to run it and gingerly drive it to a local tuner. If you want that done, then I need your tire, and axle size.
