you are literally gettin info from blindsquirrel, who, is one of the most knowledgeable on this page.
If you want someone to do your tune, itll be $500-1500 dollars
L C
my extent of tuning is ZERO. I have had HP tuners for 3 days now and I know nothing to be clear. Im actually the blindsquireel in this lol.
Be prepared to either;
spend a lot of time reading and watching videos
or pay someone to do the tuning
or hope someone gives you a tune
Well I gave him a file that had the injector data updated for the new fuel system. Or tried to. Thought I did. Something.
Thank you blindsquirrel. I did make the changes here is how it looks now.
Trims look good, would be nice to have more channels:
cylinder airmass
INJ B1/INJ B2 PW
delivered torque
trans current gear
knock retard
and a bunch more, I'm really a Gen 4 guy and a lot of stuff doesn't transfer over.
Disable EGR if you don't have it, also there is an EGR spark table that needs zeroing out if EGR is gone.
Un-disabling the factory power enrichment settings makes the single biggest difference in how these things run. The factory settings are just plain awful and miserable to drive.
New data after blindsquirrels recommendations. Drives ok but its not running like it should. It also seems to push when off the throttle at around 25 mph and will maintain speed with no throttle input.
You need to add the channels I suggested up above.
Pushing through the brakes is from too much base running air flow. There are idle tuning guides that will help you sort that out, probably also give you a list of all the channels you will need.
Here is some data with the channels added.
I know what I will be doing this weekend. Much appreciated Blindsquirrel.
it takes a pretty good chunk of time figuring it all out.
And if you dont mess with it often, you forget much of it, as i have.
Best bet, is to take a step back, clear your mind, and go at it again.
mr squirrel is giving you hints at what you need, but he doesnt give the answer. You wont learn if handed everything.
There are steps to tuning.
start with Base running airflow. It takes a weekend to do, becuas eyou need as cold as you can get it and run the engine with no cooling fans up to like 220 if you can hit that.
then shut it off, and wait until sunday morning to do the next step.
Then you can go into VE tuning.
After VE is MAF tuning.
Then PE tuning with wideband.
this can take weeks if you cant work on it 8 hrs each day.
Update, reset the TPS and IAC which solved my high rpm issue. I’m pretty close to having a running tune and will post shortly. All the help is appreciated.
