If you have already paid for the User Defined Parameters, you can use this Xdf to modify the cluster speeds, Im not going to spoon feed you but this is a start to add extra parameters to.
I appreciate you Drill! I respect your work on this platform.
Edit: The base offset was a character off, here is the updated one.
Attachment 139820
My direct knowledge is only simos18 specific, but if you buy a winols mappack/OLS file you can then manually create the XDF from that info...the file will have many maps defined with all detailed defined. This is probably what you're looking at most realistically to add a few maps here and there and not too much $ or time invested. Places like nefmoto are probably a good place to start looking to buy mappack/OLS file or similar. WinOLS has an export to XDF feature but you need paid WinOLS + XDF feature....at that point you'd probably just be editing files in OLS anyways.
A friend of mine does have winOLS, so I could utilize that. Time isn?t too much of an issue but money on the other hand? Lol
Free version of WinOLS will let you open OLS files and do what I described above. Free version you can't save edited bin files is the big limiting factor.
@TheDrill as promised: https://drive.google.com/file/d/1c1k...usp=drive_link
Looking at it a bit further, it appears that my 4H bin would be the same as the 4G bin if im not mistaken...
Thats awesome. Are you on revision 0005 too?
Weird, 0005 is the highest version i can update to.
Here's my file...
@Elaw here is 7k for youAttachment 139977
Perfect... thanks so much!
Happy Holidays!
