for example have you edit (fuel cut delta) (vvs Fault) and those are just 2 of the ones you have to edit
fuel cut delta - this deals with exceeding the RPM limiter and when the ECU will cut fuel (RPM limiter is not being breached here, does not apply)
vvs Fault - this deals with the speed sensor failure (obviously does not apply here)
Anything else? I'm here all week.
why are you so angry drink a cup of cold water. what i said was those spots and many more need editing to make a official stage 1 map for 80mph... you dont know much about what im talking about i tune seadoos every day and they all run 80+ on stage 1 im giving him some good advise dont be mad this not about you hating me
Here is the tune that is currently loaded. It might be a few months before I can get back out again. The weather here has turned a bit cold.
Attachment 138805
You keep saying how you know everything about sea-doo tuning yet you keep posting obviously wrong info just like you did earlier today.
The logs show the throttle is fully open, ignition timing is correct as is fueling. There is nothing else in the ecu that will slow down the motor under normal operating conditions. If the ECU was slowing it down, it would be retarding timing and/or closing the throttle, it's not happening. The only way to generate more RPM is by adding timing, afr is ok so I'm ignoring it, and he's already around 34 degrees which is pretty much the max you want to run on 91 octane at this boost/rpm.
If you think I'm wrong than it's easy to prove me wrong. Just post what he is missing exactly. Show how wrong I am and how right you are. I'll eat crow.
It's funny he may be experiencing the same problem I am as there is a vss torque limit table that I changed a few weeks back but I haven't put the new flash in to try it out yet. His timing is being pulled by about 1.5 degree so it could be that table. There is a "torque request" parameter that I have been logging and it shows something is still holding it back from full advance. I will be loading it in this weekend and can update on any changes.
I just had a look at one of my older logs when my ski was stock. At 82xx RPM I was seeing 72 mph in the logs, you're seeing 73, this was with only 27 degrees of timing at WOT, you're lighter than me by a good chunk as well.
I have one of the "slow hull" '22 RXPs, different than T3 but can be compared somewhat.
