You should ask F.A.S.T for the Lambda ranges, this way you can match your stoich AFR instead of theirs.
I will bring this back up since they have changed our scanner and put no predefined FAST wideband setup in this new style, really ticked off cause I cannot figure this out and my new turbo setup is useless without my wideband setup.
New wideband is ~$200. They've came so far since that one was released I wouldn't even worry about trying to use it.
What is the formula for the WB? Look at the how to stickies--one of them walks through step by step how to setup a WB in Scanner V3
so here is my scanner layout, I know for a fact those settings for the wideband are correct, I dug my old laptop out and those settings were in it for the fast WB and I then went and tried it in my car, sure enough old laptop scanned great. I must just have something stupid wrong.
Yeah, those def. aren't the right settings unless something is just plain wrong with the WB
What is the formula that you are using?
Save/post the transform that you're using for the WB
