Any more information or link I'm missing
It?s honestly a trial and error thing. This SOTF has a weird idle to it that I could never figure out why. I perfected mine pretty well but ended up abandoning the SOTF stuff for now. It works great but takes a good bit of time to get just right . You can PM if you?d like
Just applied the patch on my 04, but it only shows as having one slot available, I should have 3 shouldn't I?Attachment 119461
what do you mean the latest ford flash? I'm trying to get this to work on my 07.Attachment 123524
If 05-07 it needs to be on the latest ford flash, example VXCF9H7.
sotf for 6.4????
ive done a lot of 6.4 sotf tunes but your tranny isnt going to like it.
I'm working on attempting to flash my 05 to the latest ford version and I'm not able to get there just yet. I try to open the OS tab and it is blank, both on the SOTF file provided in the initial post and my 05 file. My base file is version VXCF4DB. When I try to write that SOTF file it says I do not have the ability due to mismatched VIN I assume. Would like to make sure I can at least write it before I move forward.
Attachment 141278
You read your truck.
Save the file
Copy the file
Open the OS and tab and patch the SOTF and save the file as SOTF
You can?t just write that file in this thread, they take your original base/stock read and input the SOTF patch to your base/stock file.
Ok, well, my OS tab is still blank so I have an issue somewhere, I have the latest software version and view set to advanced. I opened a file for my GM truck and the OS tab works on that file, not sure why I cant access anything.
Your truck on the latest flash from ford?
whats your hex strategy?
Post your stock file ecm/tcm
