Just the CM2200, or all Cummins ECM's?
Only tested on the cm2200 at the moment but I see zero reason why I would be able to extract it on the cm2350 and cm2450 as well
It’s a painfully slow process to get out. If I had much more costly equipment I’m sure I could get it out much faster, easier and with more data that I still cannot access.
The attached tune file with the ccv/ccp code removed on the first post does work on the 2010 and 2011 trucks, however, cruise control will not work if that tune file is used on those model years
Working on my own custom SOTF for the above attached file now. Hopefully it?ll go relatively smoothly and quickly.
That would be awesome! Would your SOTF require a physical dial to change the resistance of some sensor? Or are you hoping for a more graceful approach:)
Awesome work!. Any chance i could bet a copy of the extracted firmware? Thanks!
Calibration.bin files can be found online. As far as data from “non readable” areas, what I have is incomplete and painful to get out and won’t be leaving my hands
