Any eta on enabling the tow/haul mode adjustments on the f150's?
Awesome thanks Eric!
You da man!!! Haha
OK, Tow/Haul stuff is in all the 11+ Truck definitions.
Under Fuel > Open & Close Loop > Long Term Fuel Trims, I believe the Min Learn Limit and Max Learn Limit are backwards.
WOT Fueling Table, Desired stoich missing from 06 explorer 4.0
There are not many trans settings for the auto. WOT shift points and tq switches only
No matter What i do i cant seem to get it to run more than 13-14* timing at wot. Perhaps its missing spark reference tables or something? (could just be me lol)
I'm glad you posted this. I had the same problem with an explorer. What I did was went into the global spark adder and added timing that way. It worked. Now, let me be the first to say, I don't know 100% if that's the right way to do business but it worked nonetheless. Your question was one I was about to post up myself but I'll wait and see if anyone else responds to yours because; it sounds like it could answer my question as well.
is there a way to set up a commanded lambda vs Actual Lambda Histogram? Also, why is there no line to grab a hold of in the scanner to scroll through the charts?
Thanks!!
minimum timing table, still not available
Is there any tables for the f150 Ecoboost relating to 4 wheel drive? Anything for the E locker so we can set a different Rpm to be disabled?
Is there a minimum throttle blade position I am missing on 2014 Mustangs. Didnt see Minimum spark on 14 GT either. New to Fords so I may be looking in wrong area..
Do we Request new Ford scanner here or email support/
